AutoCAD Forum
Shift Overrides
5 REPLIES 5
notta79
352 Views, 5 Replies
Shift Overrides
Hi i am have an issue with the shift overrides not working when there is an image under where i am working.
In the same drawing for example i can use shift to either select more than one point in a polyline, or to change betweentrim and extend or to fillet with a raduis or to a point.
but when i try to do this with an image in the background it doesnt work.
i need the image as i am tracing shapes.
thanks in advance
5 REPLIES 5
maxim_k
in reply to: notta79
Have you tried to lock the layer with the image?
Have you tried to set SELECTIONPREVIEW=0 ?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
doben
Are you by any chance using Acad Map or Civil3D?
If so, type "MAPIOPTIONS", then under the "General" tab deselect  "Shift+Left Click Image Select"
notta79
thanks maxim i have tried both of these no luck,
Doen i have a civil 3d licence using just the normal cad not the civil part for this,  i have tried the mapoptions but no general tab see attached image
doben
Note the "I" -  MAPIOPTIONS, not MAPOPTIONS.
notta79
Thanks worked i did misse that "I"
”Boost
