We are working on one project with a mix of Revit 2014 Structure and AutoCAD 2014.
I created a Sheet Set in ACAD but is there any way to include the Revit sheets into this Sheet Set?
You could export your Revit Sheet(s) as .dwg files. and load those Layouts into the AutoCAD Sheet Set. Since the link will remain in the Sheet Set, when you make revisions to the Revit Model and reexport to .dwg to will update the Sheet Set.
To my knowledge, there is currently no way to link a Revit Model or Revit Sheets to the AutoCAD Sheet Set.
If you wish to pursure this solution and need some further direction, I'll be glad to help.
