Is it just me or can you not map any of the revision number, revision date etc. for each sheet to the sheet list table?
Really annoying, i guess add it to the Autocad Development Minefield.
Unfortunately, REVISION NUMBER value is not accessible. To track revisions, create a custom property on the Custom tab. See this link.
You can however add a custom properties.
3. Add a custom property. As owner, select "Sheet". Ok.
4. In the the project navigator, right click on the sheet and set the value for the revision number.
5. Right click on the sheet and select "Insert Sheet List Table"
6. Click Add and select the property added at step 3.
This maybe possible to with LISP though. Anyone?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Yes It is simple solution but it is the worst. So tell me why are others sheet properties in autocad, which I can not use it in different places? I need same thing in Sheet List Table. Why I should have to have same thing twice? Thanks...
Dear petr pospisil
why, are the wrong question to ADSK it is since R12 Back in 1992/ 1993 that Autocad works.... like most what you know
there was the Time to go on a 75% level
if you woud like more confort ... spend more mony
just to explain
ob Path or Drwaing List support
Vault dosent work with Plant
no Objekt betwenn ACA / Revit
Mep and Plant dont work togehter
to visule you need Navis ( whta´s not realy a ADSK Produkt )
so dont waste Time to ask why , spend it too find 3td Party Tools that will do that work that ADSK not able to do for you
cu cw
