I'm stumped. I have multiple versions of AutoCAD on my machine. No matter what I do when I dbl click on a DWG file it opens in R2014. I want it to open in R2015.
So I "right clicked", chose "open with" / "choose default" and went to the R2015 folder and clicked ACAD.exe, it opened in R2011!
It then goes back to opening in R2014 the next time I dbl click.
There has to be a way around this. In the registry maybe?
Help!
Solved by chicodon. Go to Solution.
I tried opening R2014 and closing. It still opens in R2015 with a dbl click. Same with right clicking and choosing open with R2011. It opened and I closed. Dbl click opens R2015. Somehow by "repairing" my R2015 installation it took care of the problem.
I see what you are saying about AcLauncher.exe though. I'll take your advice.
Okay, how exactly do we download and install AClauncher in the explorer (from online or autodesk, if it's possible) if we do not have it in Autocad 2015? Or does this mean I need to have two Autocad versions (2012 and 2015) installed so that the Aclauncher can work for both versions? Or does Autocad 2015 have a different Aclauncher than Autocad 2012?
