AutoCAD Forum
Select Menu
3 REPLIES 3
drguitarum2005
342 Views, 3 Replies
Select Menu
Somehow I activated a mode where when I click on an object, if there are several objects there, it will bring up a little menu to pick which one I want, similar to Inventor if you hover or say "Select other...". How do I toggle this mode? Turns out I like it sometimes but usually I don't need it. Thanks!
3 REPLIES 3
doni49
in reply to: drguitarum2005
It sounds like you're describing "Selection Cycling".  Are you seeing something like this?
There are a few ways to toggle this on and off.
Ctrl+W
or there's a toggle button at the bottom of the acad window:
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
drguitarum2005
in reply to: doni49
Thanks sir!
doni49
Glad to be of assistance.
Don Ireland
”Boost
