Somehow I activated a mode where when I click on an object, if there are several objects there, it will bring up a little menu to pick which one I want, similar to Inventor if you hover or say "Select other...". How do I toggle this mode? Turns out I like it sometimes but usually I don't need it. Thanks!
Solved by doni49. Go to Solution.
It sounds like you're describing "Selection Cycling". Are you seeing something like this?
There are a few ways to toggle this on and off.
Ctrl+W
or there's a toggle button at the bottom of the acad window:
Don Ireland
Engineering Design Technician
Glad to be of assistance.
Don Ireland
