AutoCAD Forum
Scripting Tool
2 REPLIES 2
derekanderson
984 Views, 2 Replies
Scripting Tool
I just installed Building Design Suite Premium 2014 on my computer.  Since then, my Autocad 2011 has been acting terrible.  Always crashing, etc.  So, I will just start using Autocad 2014.  However, I cannot find a decent scripting tool for 2014 - 64 bit.
In 2011 - 64 bit I was using Cadig's AutoScript.  However it doesnt seem to work in 2014.  Whenever I try and load the .arx file, it errors out and tells me that it's not compatible.  I see Autodesk Labs withdrew their support for Script Pro back in 2012 (that sucks).  So, what is everyone using as a utility to run scripts in Autocad 2014 - 64 bit.  A large part of what I do needs to be scripted as I work in series of 100's of drawings and some changes can be much faster running a script.
My computer is running Win 7 - 64 bit and I'm running the 64 bit version of Autocad 2014.
thanks.
Tags (1)
2 REPLIES 2
pendean
in reply to: derekanderson
There are a few 'for purchase' on the Autodesk Exchange Apps webiste: http://apps.exchange.autodesk.com/ACD/en/List/Search?query=script&facet=&collection=&sort=dateUpdate...
olivier.eckmann
in reply to: pendean
I use Autoscript version 3.2 with my MAP 3D 2014 without any problem.
Olivier
”Boost
