AutoCAD Forum
Scales
4 REPLIES 4
cslater9
325 Views, 4 Replies
Scales
Hi I have a contour map at 1:1000 and I want to make it 1:40000 so I can export it into sketchup to make a 3D model. Can anyone help?
4 REPLIES 4
dmfrazier
in reply to: cslater9
Is the map not drawn (in model space) at 1:1?
In what sense is it currently "at 1:1000"?
cslater9
in reply to: dmfrazier
When I plot it at 1:1 its coming out at 1:1000
murray-clack
For a 1:40,000 scale, use the SCALELISTEDIT command to create a new scale factor that is a 1:40 ratio
dgorsman
Scale names aren't necessarily the same as the value; they could be called Fred, Wilma, and Barney.  In particular with civil design work, you will see scales which are off by a factor of a thousand (1:1000 name is actually 1:1) since the model space is in meters and paper space is in millimeters.  So make sure the scale(s) you are using are, in fact, what you intend them to be.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
”Boost
