Is there a way in cad 13 to scale vertically only?
Solved by Patchy. Go to Solution.
BLOCK command and make a block out of it/them, give it a name
INSERT that block name and follow the prompt for X and Y scale.
Group is not a block.
The easiest way is to copy the 3D objects to clipbpard (Ctrl+C) a paste them back as a block (_PASTEBLOCK). Then change the Z-scale property of the pasted block using the Properties palette (Ctrl+1) - see the sphere+cube scaled in Z:
Vladimir Michl, www.cadstudio.cz www.cadforum.cz
Do that all the time to fake items on a 45 degree angle.
X = .707
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
