AutoCAD Forum
STL Files from AutoCAD for 3D printers?
7 REPLIES 7
Message 1 of 8
Drafter1981
16336 Views, 7 Replies
O.K….1st of all I want to say thanks again to Patchy, benedictos.virgilio, & Yorx57, for pointing me in the right direction on the post 02-11-2014 regarding creating Odd Shape cones made with loft or helix. That being said, here is my new dilemma:
The 3D files I have created DO NOT seem to convert properly into other usable files from AutoCAD. I have been told the best way to get these files “Fabricated” is to do a direct export from AutoCAD *.DWG files to *.STL files, for 3D Printing. I sent the files over (“CONVERTED”) however, it seems the export, or conversion is not a clean or workable file.
The export files states these are *.STL however the contact person I’ve been sending files to cannot access or open these files. Am I missing a step here or perhaps do I need some “ADD-ON” from Autodesk? As usual any information or help is appreciated.
Milt Fitzgerald (a.k.a. Drafter1981)
Fitz’ Digital Cad Service L.L.C. (Consulting Business)
https://sites.google.com/site/fitzdigitalcadservice/
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: Drafter1981
You do not need any add-on.
It is difficult to make CAD diagnosis from pretty pictures (rather than actual dwg files), but my guess from the screen capture is that you have modeled as a surface body rather than as a solid body (run List or Properties to check).
AutoCAD must have a solid body to stlout an stl file.
You might attach the dwg file here, and if you confirm that is is solid - attach the stl file here as well (zip it first).
Message 3 of 8
JDMather
I do not know what this means.  Do you mean you converted a surface body to a solid body?  The AutoCAD command is stlout.
Follow the command line - what does it say?
Message 4 of 8
JDMather
in reply to: JDMather
What is the size of the resultant stl?
The resolution of the stl can also be changed, but first we need to verify that you have a manifold solid body.
Message 5 of 8
Drafter1981
JD,
(Hope you don't mind JD) Thanks for your information and sorry for not getting back to you any sooner. As usual, on my end I had no idea if any of my post were getting through, (I must be the only one getting these input glitches). Anyway,  I will review the information you provided.
I also attached what I thought was the STL file but apparently not.
Thanks again,
Message 6 of 8
JDMather
Your stl file works fine here.
What software is your contact person using?
Did you send them the zipped stl?
Do they know how to extract a zipped file?
Message 7 of 8
Milt-Fitz
JD,
Thanks again!
After your review of the files, several other 3D companies also comfirmed that the files I converted / created will work.
I'm still in the process of getting prices and if I find someone that is resonable I will get this printed just to say
"Yes, We can do that"!!!
Thanks again for your input!!!
Siemens Industries (Full-Time Office Position)
Message 8 of 8
JDMather
in reply to: Milt-Fitz
Just make sure your units are correct.
Tell them the bounding box size.
You should check -dwgunits in the dwg (with the dash - )
and you should check the stlout Options units to make sure the output units match your intended design units.
I have seen a lot of models printed wrong size because of mis-matched units (in, mm, cm).
”Boost
