When you right click on a hatch pattern...
Is there a way to Generate only the perimiter boundary, without the 'islands'?
I don't believe there is. The only thought I have is to delete the island boundaries after they are created.
Could you simply control the extent of the hatch or the "islands" during the initial placement of the hatch? When you expand the Hatch dialog box, that you have some options for how the islands are treated.
Yes... you could.
In this case the hatch(s) was predilivered to us in the Reflected Ceiling Plan from the Architect... I was hopping to generate closed plines around each, but without the innerloops.
I did find a lisp that will do this.. but it's not fool proof... it doesn't work in every case.
I believe if you right click on the hatch and click on the "Hatch Edit" option, the Hatch dialog box will reappear and you can revise the Islands settings to some extent. Depending on how complicated the hatch area is, you might be able to use this to adjust the hatch to be what you want.
I'm using 2012 here but I doubt if 2014 is much different in this respect.
Attached is the test dwg I started out with. First I created a hatch with "islands". Then I deleted all the polylines that were used as boundaries so that it is now just a hatch object.
Follow the prompts and it will create polylines of your boundaries (yes it will include the islands). Delete the islands.
If there are so many islands that you don't want to deal with having to delete them all, then copy paste your hatch object into a new dwg. Re-create your boundary there and then copy/paste only the outer boundary back to your desired dwg.
Don Ireland
Engineering Design Technician
