Good morning. I opened my AutoCAD 2013 program this morning and all my preset ribbon are gone. I cant even right click on the tool bar to get the menu up to add them back. Can some one help. Thank you
i get a command saying the ribbon does not have any tabs or panels currently loaded. I shut down AutoCAD and re-opened it and nothing has changed. I had all my ribbons on it on Friday. I dont know what happened
I've seen this happen under a couple of circumstances. First, check your workspace - it may not have have any content (as the text says). This can happen if all of your content was on a CUIx that cannot be found, and you have your workspaces set to automatically save changes (not present is a change, so the new "empty" status is saved). Second, if they are there, make the workspace current and the content should load.
I typed in the WScurrent and nothing happened. Asked for a new value and i typed 1 and it said it was invalid.
If nothing is there, then it lost track of the workspace.
new value = name of your workspace (or any workspace) already defined in the CUIx. Type in the name of your workspace or another wosrkspace that you had in AutoCAD.
Is that the name of your workspace, 1??
