AutoCAD Forum
Ribbon disappeared
13 REPLIES 13
Message 1 of 14
immunoman
9138 Views, 13 Replies
Ribbon disappeared
My ribbon disappeared when I clicked "dock" on the Tool Bar. Can someone tell me how I can get it back?
13 REPLIES 13
Message 2 of 14
nestly2
in reply to: immunoman
If you clicked "undock" the Ribbon will turn into a floating palette. Click on the titlebar again, check "allow docking" then drag it back to an edge.  If it's actually "gone", try typing RIBBON at the command line and/or switch to another workspace, then switch back (assuming you haven't also changed the variable for automatic workspace saving)
Message 3 of 14
immunoman
in reply to: nestly2
My ribbon now looks like this, but how do I get the tools to appear the way they do under the home tab without having to click the menu item? Thank you for your help Smiley LOL
Message 4 of 14
TC-ESHse
see that little gray sqaure with an arrow in it to the FAR right side . . . click that and it toggles you through the different views of your Ribbon.
Message 5 of 14
nestly2
Also, it looks like you've loaded the Ribbon tabs multiple times based on all the duplicate tabs.  This may correct itself when you shut down and restart AutoCAD.  If it doesn't fix itself the next time you start AutoCAD, we'll help you get that fixed too. Smiley Happy
Message 6 of 14
immunoman
in reply to: TC-ESHse
Well, it's back where it should be, but about 6 sizes too large? Is there a way to get it back to its normal size?Smiley Frustrated
Message 7 of 14
nestly2
Well, that's one I haven't seen before.  My suggestion is:
Start > All Programs > Autodesk > AutoCAD2014 > Reset Settings to Default
Message 8 of 14
immunoman
Nice fix! Thank you!Smiley LOL
Message 9 of 14
Charles_Shade
And maybe just a computer reboot will put all right.
+1 on the multiple Ribbons being loaded. Not seen that before either.
Maybe something more is hosed up in the CUI?
Message 10 of 14
heinsite
in reply to: Charles_Shade
This solution might be moot now, but as I read thru this I wondered what would have happened with selecting Drafting & Annotation in the Workspace Switching dialog.  Unless one of these odd layouts had been saved over it that might have reset the ribbon too.
Dave.
Dave Hein, P.E.
Message 11 of 14
Stogy1
i have lost my tabs, it dosnt give me an option to load any. what is going on?  where do i reload my Ribbion
Message 12 of 14
iri_901
Se me ocultó la barra de herramientas y no se como mostrarlas nuevamente, por favor me dice como?
Message 13 of 14
iri_901
Me urge,plis
Message 14 of 14
john.vellek
in reply to: iri_901
HI @iri_901,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I am unsure if you mean the Ribbon or Quick Access toolbar.
For the latter take a look at this article that describes how to use the QAT.
For the Ribbon, please look at this article.
If you still aren't having luck with these try a Reset Settings to Default.
John Vellek
”Boost
