Hola!!
Ocupo que me ayuden con un problema de vizualizacion, tengo autocad 2014 y tengo una pantalla AOC de 21.1", a la hora de ver el dibujo en la pantalla salen alargados. ¿Hay una forma de configurar ese problema?
You likely need to change the Monitor aspect ratio to its Native setting or find another setting that meets your needs and has the same aspect ratio as the Native ratio.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
