Back in the R2000 days, I quite literally made a career out of AutoCAD and AccuRender, and using those together was like second nature to me. But that was a long time ago... Skip ahead to today: AutoCAD 2013, no AccuRender. My boss asks me to render a few items, and I figured that shouldn't be too much of a problem. But it's been a long time, and I'm running into all kinds of roadblocks. But here's a big one:
"Render" and "Render Region" seem to be two very different things. I want to render out to a file, so I specified a location in the Render ribbon using the little save/teapot icon. However, the item I am rendering is quite vertical and my display is widescreen horizontal. Using the "Render" command will save to a file, but it insists on rendering everything visible on the screen. "Render Region" allows me to select a smaller area to render, but I cannot get it to save out to a file. I know that SAVEIMG will output the results to a file, but those results are limited strictly to the physical resolution of my display. I want to be able to save at the much higher resolutions that are possible by saving directly to a file.
Question #1: Is it possible to render directly to a file using "Render Region"? If so, how?
Question #2: If I must use "Render" to save directly to a file, how can I select a smaller area to render? This is my first day touching AutoCAD rendering in about 10 years, so I am sure there are a lot of details that are eluding me. Specifying a smaller area to render must be possible, but I can't figure out how. Thoughts?
Thanks for any help - it is shocking how much of this has changed, or that I've simply forgotten.
- CF.
Start command _RPREF ... there you can set the resolution for rendering.
>> [...]how can I select a smaller area to render?
No, you can't render "Region" directly to file. But you can create a layout with a viewport, make that viewport more landscape or more portrait and render that, but at least: the aspect ratio of the resultion (see above) is the number that defines more wide or more height.
- alfred -
