I have a thrid party software program that exports Release 12 DXF files. These files are just 2D lines art that I then open with AUTOCAD 2000 with no problems, but I have a friend who has AUTCAD 2014 on his computer and he has let me try it out before I upgrade my software. When I open these same files with 2014 version, I lose the dimensions. What I mean is that the file opens correctly, but all of the dimensioning that was in the DXF file has disappeared. Is this a problem with 2014, or simply just a setting that is incorrect in his copy of 2014? Does anyone have any advise related to this issue. I am holding off upgrading my software because of this problem. Thanks for your help.
My friend is still in college and using an Educational Version of 2014. Could this have anything to do with it, and can he submit that request to AUTOCAD since he is using this version?
thanks for your help.
I count 21 dimensions in this drawing, however none of them actually show up.
I can select them all, and change the dimstyle to "Annotative" (which is a dimstyle that gets created in any new DWG file) and they show up. Alternatively, I can make any small edit to the STANDARD dimstyle, and they show up fine.
Those are the right dimensions, and we ran a test with my friend and he found the same thing. They are there, you just need to do something to the to get them to show up. This is a way to work around the issue, but I just wished you didn't have to take the extra steps.
Thanks very much for your help.
I will consider this thread closed from my point of view.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
