We had soem issues with a user's Windows 7 x64 account and had to delete her Windows C:\User\ folder and re-create it. We did make a simple copy backup of the C:\Users folder.
We did not do an Export of her AutoCAD 2014 profile but do have the entire folder structure and files from her old C:\Users\.
I hoped that by simply copying the files onto the new account her settings would also migrate..but no dice.
How can I, by having all of the files, get her AutoCAD profile/settings to replicate?
Solved by dgorsman. Go to Solution.
In most cases, when "settings" are referred to its how the program looks. Unless there are other settings you are referring to?
Profile is only part of the equation. That stores some system variables as well as search paths. The other part of the equation is the Main and Enterprise CUIx files (dictated by the appropriate search paths in the profile). That will determine which Workspace(s) is/are available, which determines the toolbars, menus, Ribbon tabs/panels, and other UI elements are shown
Thank you.
I think I have most of that taken care of now.
The user no longer is seeing her Command Aliases. Is that is a specific file that i may be able to copy over?
Yes, it is; and yes, it should. AutoCAD will use the first PGP file it finds in the search path, so I'd ensure the folders are pointing where you think they are before copying the file. It could be finding another version in a higher-ranked search folder, in which case copying won't help you.
