AutoCAD Forum
REVCLOUD and Layers
7 REPLIES 7
Message 1 of 8
hanchris
1737 Views, 7 Replies
REVCLOUD and Layers
This is just a question that is on my mind everytime I use this block; but it is not a show stopper in the least, so I have never thought of asking it.
1. Draw a Rectangle
2. As a new command, Change the layer. I personally always use "CLOUD".
3. Use REVCLOUD to make the rectangle above to a cloud.
Did the cloud change back to the previous layer the rectangle was on? It does for me and has for the past few versions of AutoCAD and on different machines. I usually just remember to change the layer before I create the initial object or after the REVCLOUD is created; but every so often I mix the steps around and this question pops up, "Is there a point to this?"
Anyways, as I stated before this is mostly to statisfy my own curiousity and wondering if there is some reason Autodesk programmed it this way. I believe all or at least most of the other "non-layer" commands do not change the layer and from my knowledge of the DWG database - through simple LISP and .NET programs - it does not keep "past data".
7 REPLIES 7
Message 2 of 8
pendean
in reply to: hanchris
It's always done that: get in the habit of drawing on the final/destination layer with your rectangle or change layers afterwards (since you are going to do it anyway).
A little LISP automation would get you around the issues.
Message 3 of 8
rendarin
From my experience it doesn't revert to the layer the object was on, but rather whatever your Current Layer is set to.
For example, I draw a PL and set it to Layer REVCLOUD; if my Current Layer is still Layer 0 and I use the REVCLOUD command, it creates a revcloud in the Layer 0.
Message 4 of 8
skintsubby
in reply to: pendean
(defun c:rv ()
(command "undo" "begin") ;start undo group
    (setq osmd (getvar "osmode"))
    (setq echo (getvar "cmdecho"))
    (setvar "cmdecho" 0)
    (setvar "osmode" 0);turn off snaps
  (setq pt1 (getpoint "\nPick Revcloud start point: "))
  (setq pt2 (getcorner pt1 "\nPick Revcloud end point: "))
   (initget 1 "Yes No")
 (setq rsp (getkword "\nInvert Revcloud? [Y/N]:"))
 (if (= rsp "Yes") (= rsp "No"))
  (command "RECTANG" pt1 pt2)
  (setq clay (getvar "clayer"))
             (command "_layer" "make" "Revision Cloud" "")
             (command "_layer" "color" 1 "Revision Cloud" "")
             (command "_layer" "ltype" "continuous" "Outline Heavy" "")
  (command "revcloud" "a" 5 5 "" "l" rsp)
  (setvar "clayer" clay)
     (setvar "osmode" osmd)
    (setvar "cmdecho" echo)
 (command "undo" "end")
  (princ)
Message 5 of 8
pendean
in reply to: skintsubby
Nice.
Message 6 of 8
pkolarik
I have the revcloud on a tool palette, where it's forced to put the revcloud on the layer I set the icon up for regardless of what my current layer is. Works every time.
Message 7 of 8
GrantsPirate
I use layer-director from lee-mac.com to set layers automatically for many different commands.  Works really well, take a look.  Not affiliated with lee-mac.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 8 of 8
hanchris
Thanks for most of the feedback and I did not think that it puts it back on the current layer; but that makes more sense from a programming standpoint.
Thanks also for the tips and tricks of managing layers and this command.
”Boost
