AutoCAD 2013/2014/2015
Active Contributor
mazh045
Message 1 of 12 (274 Views)
Accepted Solution
Quickest way to cut this interception?
274 Views, 11 Replies
04-18-2013 09:25 AM
Hi everyone,
I'd like to hear people's opinions on how they would do to cut the selected left line in two to the interception point of the perpendicular line and the left one as quick as possible?
Wish I could have a better way than to trim the bottom part, and draw a new line.
If you have a quickest way to make this, I want to hear it =) Thanks
David
*Expert Elite*
Patchy
Message 2 of 12 (267 Views)
Re: Quickest way to cut this interception?
04-18-2013 09:29 AM in reply to: mazh045
Break, but the one comes with autocad doesn't work that good. You need break at intersection autolisp.
Active Contributor
mazh045
Message 3 of 12 (265 Views)
04-18-2013 09:32 AM in reply to: Patchy
Thanks for your answer,
but, the problem with break is that this isn't precise, or maybe I've not check the command in details. When I try to break something, I've no snaps. Don't know if it's the case of others too?
Active Contributor
mazh045
Message 4 of 12 (264 Views)
04-18-2013 09:33 AM in reply to: mazh045
Dang, sorry, you're right... Thanks for the tips!
Valued Mentor
sthompson1021
Message 5 of 12 (221 Views)
04-18-2013 11:40 AM in reply to: mazh045
Hi, you don't need a lisp routine for this. Just use the break command, select the line, when it asks for second point enter F and click on the intersection (make sure your snap is on). It will then ask for second point. Just click on the intersection again.
*Expert Elite*
braudpat
Message 6 of 12 (218 Views)
04-18-2013 11:41 AM in reply to: sthompson1021
Hello
YES but I believe that Patchy said the standard "Break" command is not very fast/efficient !
Bye, Pat
Bye, Pat
Valued Mentor
sthompson1021
Message 7 of 12 (214 Views)
04-18-2013 11:50 AM in reply to: braudpat
I guess it depends on your preferences. To me typing 3 letters, 2 space bar clicks, and three mouse clicks is about as fast as I need to do it.:smileyvery-happy:
Valued Contributor
gwhite
Message 8 of 12 (207 Views)
04-18-2013 12:01 PM in reply to: mazh045
below is a tiny lisp routine that I have used for many years - the ba stands for "break at" and you just select the entity you want to break and then, with osnaps on, where you want to break it. Two keys, a spacebar, two clicks - done.
(defun C:BA ()
(setvar "cmdecho" 1)
(command ".break" pause "f" pause "@")(princ))
*Expert Elite*
Patchy
Message 9 of 12 (202 Views)
04-18-2013 12:06 PM in reply to: sthompson1021
I race ya.
Break hundreds of intersections, your finger joints will be painful.
*Expert Elite*
braudpat
Message 10 of 12 (200 Views)
04-18-2013 12:08 PM in reply to: gwhite
Hello
YES --> :smileytongue:
But my preferred Autodesk Software is AutoCAD MAP (or CIVIL)  !
So with MAPCLEAN / Break at Intersection/Crossing : No problemo !!
Bye, Pat
Bye, Pat
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
