AutoCAD Forum
Quadro K2000 is not certificated ? Autocad 2013
5 REPLIES 5
hieunguyen84
845 Views, 5 Replies
I installed autocad 2013 sp2 and driver for quadro K2000 in autodesk hardware certificated's page. I have enable hardware acceleration and tuneup log show K2000 is not certificated. How to make Quadro K2000 certificate ?
Tags (1)
5 REPLIES 5
pendean
in reply to: hieunguyen84
Which OS?
hieunguyen84
Windows 7 Ultimate 64bit
pendean
This is a laptop, correct? AutoCAD may still be using the onboard INTEL graphics card instead. Did you disable it in your laptop's BIOS first?
hieunguyen84
This is workstation, cpu e3-1231 v3 doesn't have gpu integrated
dgorsman
Don't worry too much about it.  AutoCAD doesn't phone home to keep the list up-to-date (it checks a local list which isn't updated from online), so unless its causing grief it shouldn't matter.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
”Boost
