AutoCAD 2013/2014/2015
Active Member
Message 1 of 6 (228 Views)
Accepted Solution
Publish Command
228 Views, 5 Replies
10-31-2012 02:42 AM
Probably a silly question but after 2013 was installed in my colleagues computer he now has the option to include Layouts when opening the publishing command, which didn't happen before.  It is a slight pain removing these from the selection to be published and I was wondering how I get it to only select models and not layouts when opening the publish command as default.
*Expert Elite*
pendean
Message 2 of 6 (220 Views)
Re: Publish Command
10-31-2012 05:11 AM in reply to: rabruce
What version did you all use before 2013? Do you all save DSD (drawing sets) to reuse?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
Message 3 of 6 (216 Views)
Re: Publish Command
10-31-2012 05:32 AM in reply to: pendean
As I mentioned it was a colleague who used it so I don't know about the .dsd file, but the version was 2012
*Expert Elite*
GrantsPirate
Message 4 of 6 (208 Views)
Re: Publish Command
10-31-2012 06:56 AM in reply to: rabruce
Open publish, right click, uncheck Include ModelSpace, finish.  That should be set until it is changed manually by the user.
*Expert Elite*
pendean
Message 5 of 6 (205 Views)
Re: Publish Command
10-31-2012 07:44 AM in reply to: GrantsPirate
... I think they need to uncheck INCLUDE LAYOUTS WHEN ADDING SHEETS is I'm not mistaken.
OP, it's done the same way in R2012: ask your user to document and save it.
Active Member
Message 6 of 6 (200 Views)
Re: Publish Command
10-31-2012 08:05 AM in reply to: GrantsPirate
I've spoken to my colleague and this has solved it.
Thanks for all your help.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
