Every time I load a new drawing I get a Proxy Information box opening first. It says that there are 2 missing Applications. AeccvBase100 and AeccLand100. I can't seem to find these enablers to install. Any suggestions?
Solved by jggerth1. Go to Solution.
sounds like your template has some vertical civil information embedded in it. Simplest thing will be to start your drawings with a template that is NOT infested with AEC objects. If you're not doing civil work with C3D, that informaion is probably superflous and just occupying space in your drawings.
You should also download and install the Civil Object enabler for your version of Acad
