AutoCAD Forum
Properties Palette Problem (Autocad 2014)
9 REPLIES 9
Message 1 of 10
6316 Views, 9 Replies
The properties Palette is not showing up. I read that if you uninstall Autodesk 360 via the control panel the properties pannel will not work properly both on Autocad 2013 and 2014. I didn't uninstall Autodesk 360 but still the properties palette is not working. All i can see is an Option bar and the customize box.
9 REPLIES 9
Message 2 of 10
pendean
Got pushed off screen perhaps?
Message 3 of 10
in reply to: pendean
I don't really know if it really is a problem or its just that I really do not know how to use Autocad. Here's a screenshot of the problem.
Message 4 of 10
Alfred.NESWADBA
your screenshot does not show the properties window, that is something that you pulled out from the ribbon, whereas I don't know which ribbon-panel that is, do you have customized your ribbons`?
At least you can send that ribbon panel back (to the default, docked position) by clicking into the top-right (small) icon in it's border:
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 5 of 10
nestly2
in reply to: Alfred.NESWADBA
Alfred.NESWADBA wrote:
your screenshot does not show the properties window, that is something that you pulled out from the ribbon....
I believe the OP's screen capture is showing a malfunctioning Quick Properties window.  That it's not populated is probably the result of the same registy problem that affects the full Properties palette.
OP, did you use a registry cleaner or any other program advertised to "speed up your PC" recently?  Did you install an older version of AutoCAD after installing 2014?  If not already installed, you might try applying Service Pack 1, otherwise you may have to re-install AutoCAD.
I also notice that there are no drawing names shown in the FILETABS.  Is this an English version?
Message 6 of 10
Alfred.NESWADBA
in reply to: nestly2
>> Actually, I believe that's the Quick Properties dialog box
Yep, you are absolutely correct, it's the QuickProperties dialog and nothing from the ribbons.
- alfred -
Alfred NESWADBA
Message 7 of 10
I'm using CCleaner and I did install a previous version. I installed Autocad 2009 after installing 2014.
Message 8 of 10
Alfred.NESWADBA
then run a repair install of 2014 (admin permissions on, antivirussoftware off).
- alfred -
Alfred NESWADBA
Message 9 of 10
nestly2
Both of those are known to cause the Properties palette(s) to stop working properly.  You can try "repairing" AutoCAD2014.  If "Repair" fails to fix the problem, then you may be required to "Reinstall" 2014
On the Windows Start menu, click Control Panel > Programs > Programs and Features > AutoCAD2014 > Uninstall Change > Repair/Reinstall
related topic: http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/Quick-properties-don-t-show/td-p/3877377
Message 10 of 10
I had the same issue and "repair" didn't work.  I uninstalled SP1 and reinstalled it:  From control panel's "programs and Features" select "View installed updates".  Find SP1 from installed list and uninstall it.  Then from AutoCAD, check for product updates and install SP1.  See attached.
”Boost
