AutoCAD Forum
Project to 2D a Polygon Mesh
2 REPLIES 2
PabloAlv
1276 Views, 2 Replies
Hi!
I need to project to 2D a 3D drawing. I often use the SOLPROF tool but my current drawing is a Polygon Mesh.
Anyone have an idea on how to convert a Polygon Mesh to Solid?
Thank you in advance
  Pablo
PS: I've attached the file.
2 REPLIES 2
nestly2
in reply to: PabloAlv
FLATTEN command should make the projection without any need to convert..  Just make a copy and "FLATTEN" the copy as the operation will eliminate the 3D geometry it's projecting.
PabloAlv
in reply to: nestly2
Thank you very much! Solved!
”Boost
