Sorry if this is a super bonehead question, but how do I access Project Browser/Navigator in 2015?
In 2013 I could type it in the command line, access it from the application menu or use the icon on my quick access bar. I've tried all of these and find nothing. Even searching help only sends me to VBA Project info. I also checked the new home screen, all I find is sheet set.
Solved by dgorsman. Go to Solution.
There is no Project Navigator, Browser, or other function in AutoCAD 2015. Such features are present in some of the verticals like AutoCAD Electrical, AutoCAD MEP, and AutoCAD Architectural. Are you running one of those programs, or AutoCAD?
No problem. If you do get squared away with AutoCAD MEP, there is a dedicated board for it: http://forums.autodesk.com/t5/AutoCAD-MEP/ct-p/2036
They'll be able to provide additional help specific to that program.
