Hi, Im pretty new to AutoCAD and to this community as well, so this question might be stupid ..
Anyway, I got trouble with option move. For my homework I got a picture to draw. Most of the picture I had to make it by myself, except for the "screws". Screws were already made by our profesor and we just had to import them in.
I copy/pasted them on the same drawing, but when it comes to actuall move them I cant get them to the right location, they always appear somewhere I dont want them.
I have put some screenshots as well. Im using AutoCAD 2014.
Welcome to the Autodesk Forums!
How did you tried to move them?
Do you use MOVE command?
Maxim
Object after move command, stops existing. Then I use undo command to get it back.
What I have to get is those screws on the red circled areas, but it doesnt really work for me :S
What is the difference between copy and copy/paste?
When using the MOVE command you need to select an accurate base point and destination point. This is where OSNAPS come in. Hold CTRL and right-click to get the OSNAP menu and select an OSNAP that works for your object. You could use intersection or midpoint to select the base point on the screw and then endpoint for the destination. Try several different ones to see what works best on your objects.
