AutoCAD Forum
Problem with sweep command
17 REPLIES 17
Message 1 of 18
rohit.jain092
2928 Views, 17 Replies
Hi there. I have been trying to convert this surface (attached file)  in to a closed volume. But somehow it isnt working.
Then I tried to create this figure myself by creating two circles (one at the top and the other at the bottom) and then creating the path for using the sweep command , but it gives a error " sweep preoduces self intersecting curves".
Can anybody help me to convert this surface in to a sloid volume or if thats not possible can this geometry be created to the nearest possible approximation.
Thank you for the time. I really appreciate it. 🙂
Tags (1)
17 REPLIES 17
Message 2 of 18
maxim_k
in reply to: rohit.jain092
Try to use LOFT command instead of sweep. Use circles as start and end crossections and then fine-tune Draft angles (start and end) in loft settings dialog.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 18
rohit.jain092
in reply to: maxim_k
Maxim: Thank you for looking in to the matter.
Is there a way to find the draft angles or i have to arbitrary choose any
value and then fine tune it.
Rohit Jain
Senior Undergraduate
PEC University of Technology
Chandigarh
Message 4 of 18
nestly2
If the arc represents the intended profile, Make sure the top and bottom are circles, then polar array the arc profile around the center.  Use LOFT making sure the MOde is Solid  with the GUIDES option.
Message 5 of 18
LaserGuy
There something weird about that surface. Is in imported from another program?
Message 6 of 18
rohit.jain092
in reply to: nestly2
Hi nestly,
Thank you for your suggestion. But that isn't working either. It isn't
identifying the guide paths.
Rohit Jain
Chandigarh
Message 7 of 18
rohit.jain092
in reply to: LaserGuy
Hi LaserGuy
Yes this surface has been created from point cloud data.
Rohit Jain
Chandigarh
Message 8 of 18
rohit.jain092
Hi nestly, Can you please tell me how did you create the guide. Is it any arbitrary curve or the the actual path for this problem because when when i do it , it does not accept the guides.
Message 9 of 18
rohit.jain092
Hi laserguy
Thank you for the solution. can you please tell how did you actually do it. I have understood what you have done, but not how did you do it.
Message 10 of 18
nestly2
I made the assumption that the surface in your drawing was accurate for your purposes, so I simply exploded it.  The exploded geometry included an arc representing the profile.
Message 11 of 18
LaserGuy
Create a half section and Revolve.
Message 12 of 18
Patchy
I think that is FULL section.
Message 13 of 18
rohit.jain092
Hi nestly But when i do it says the select guide is not a valid type.
Rohit Jain
Chandigarh
Message 14 of 18
rohit.jain092
Hi laserguy
Thanks. But how do i get the 2d profile or the half section??
Message 15 of 18
nestly2
I can't be certain, but perhaps the polar array needs to be exploded so it's individual arc segments... or perhaps the top and bottom circles are not coplanar with the ends of the profile arc?
Here's a demo of how I did it in AutoCAD2013 using your drawing as a base.  --> http://www.screencast.com/t/UwPoejZNtZ
Message 16 of 18
JDMather
Hi laserguy
How tight is the tolerance you need?
Message 17 of 18
rohit.jain092
Hi nestly,
Yes i have got it now. I didnot explode the array guides. It worked fine afterwards.
Thank you very much.
Message 18 of 18
rohit.jain092
in reply to: JDMather
Hi JDMather
Thank you very much. The problem is solved.
”Boost
