i need to create a solid by extruding/offseting a spline surface (attached picture). The problem is, a solid created by simply extruding this surface "outside" would cross itself, so autocad does not allow me to do it (neither extruding, surface offsetting is working) I tried to make a cube then using this surface as a splitting spline - however a solid created this way is flat on z-axis. How can I do this ? Everything is fine with the spline as well as a surface - it's closed one. Obviously the problem is in the fact in the self intersection of the extruded solid. So maybe using it to split a solid is a better approach?
I would appreciate any help, i am sitting on this for almost 2 days now.
Thanks in advance
PRESSPULL will likely extrude it into a solid since PRESSPULL's first function is to create a region (as per Patchy's advice)
You may also try BPOLY (aka BOUNDARY command) to create a new boundary without the "self-Intersecting" condition.
Maybe post the drawing with your spline, and more detail about what you're trying to accomplish. The screenshot looks like you're modeling a guitar body, in which case the suggestions already posted should be applicable to a logical workflow.
I want to extrude that green surface in the directions showed by arrows on the picture to get a solid. There is a function that does that, it's called _SURFOFFSET. The spline you're asking is the red one on the picture. What i want to accomplish is actually a second floor of the audience balconies in a concert hall. I hope it is clear now.
Sorry if I misunderstand something, but _SURFOFFSET with option "_SOLID" creates a solid. So what's the question?
From your very first post:
If that is the question then split (_BREAK) your spline into 2 pieces, create then 2 solids and run command _UNION.
- alfred -
