Hi. I have tried to run Cadalyst 2015 test for AutoCAD on my computer, but after first 3D test, CAD stopped to respond, and after 15-20min. test get me the results. Since there is ''Not Responding'' message for all time during test, there is a problem. But my processor shows max 60-70% per core, GPU also, memory of graphic card is on 10-20% max, and RAM not more than 70% of use. So if anyone have an idea what could be a problem, please help me. Thanks in advance!
My hardware is:
- Phenom II X4 960T
- 4GB 1800MHz DDR3 RAM
- HD 4850 1GB DDR5
- SATA HDD
Really? That message tells you "it can not respond to you, because it's working on the stress test", nothing else, not a problem.
It's like you are phoning with your friend and someone else asks you something: you will tell that person "I'm busy, come later again" ... but you are real alive, nothing wrong here too.
- alfred -
first off, Acad is not a heavily multi-threaded program, so will not take significant advantage of multiple cores.
secong, 4GB or RAM? That's barely enough to get a modern winodws OS functioning, much less anything as computationally intensive as ACAD, especially on a stress test.
thow that RAM away, and put bigger sticks in -- minimum 8, slightly better 16Gb, sweet spot on the bang/buck scale seems to be 24Gb (2 -8s, & 2-4Gb sticks if your MB supports it.
