My name is Gageanu Mihai. I am a student of Technical University of Civil Engineering Bucharest. I recently bought a laptop with an i7 4702MQ 2.2 , 8GB RAM and a videocard AMD Radeon 8750M HD.
I thought AutoCAD will run smoothly but it does not. It is framing badly. I would like to mention all my drivers are up to date. Other applications run with no problems except the AutoCAD. I contacted AMD by phone and they told me I have to contact Autodesk support because this is an old problem and you have to provide me with a patch to solve the encountered issue.
I am looking forward to your answer and to a possible solution.
Best regards,
Gageanu Mihai
welcome @forums.autodesk.com!
And if they know it is "an old problem" they can't give you the info which problem it is? Strange.
>> [...] you have to provide me [...]
Here is a discussion forum, mostly users helping users, not the direct Autodesk support.
If you want to get a info directly from Autodesk you need to login to your subscription account and create a support request.
>> [...] provide me with a patch to solve the encountered issue.
We don't even know your AutoCAD release (and exact product, e.g. if it's a vertical like Civil 3D) but should provide to a link with a patch?
- alfred -
Hello Alfred,
Sorry if I sounded arrogant. but this is what they told me. I am using Autocad 2013 simple, no 3D.
Then the service packs are available >>>here to download<<< and install.
And specially for your graphics hardware: Autodesk does not write any hardware drivers for graphic hardware. So you don't get any patches for your gc-driver(s).
The only option is to look to the list of gc-drivers tested by Autodesk >>>there<<< (this is the list for AutoCAD 2013, on Win7x64 on AMD, modify the criteria if any of my assumptions are not correct).
- alfred -
Hi Alfred,
I already found the solution on an HP forum.
I had to type in the command line:3DCONFIG->MANUAL TUNE->ENABLE HARDWARE ACCELERATION.
Everything is OK now.
