AutoCAD Forum
Problem to draw arrows by pline
11 REPLIES 11
Message 1 of 12
BrianLUO
1881 Views, 11 Replies
I don't know how did it happen. When I did the confirmation after I drew the arrow, it shrank to be small. Like the pictures attached.
Tags (2)
11 REPLIES 11
Message 2 of 12
maxim_k
in reply to: BrianLUO
Welcome to the Autodesk Forums!
Does this happens every time or just once?
You can check polylne width at each vertex (both start and end) with Properties palette - select polyline, than "walk" through vertexes in Geometry section with Vertex field.
What do you see?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 12
BrianLUO
in reply to: maxim_k
Hi Maxim:
Thank you for your reply. Acturally, when I open the Orthographic Mode, it didn't happen. In addition, when I draw the arrow head individually without the tail, it was also normal.
I am really sorry to say I cannot totally understand your answer. I learnt the software several years ago and almost forget everything till now. At present, I am forced to pick it up because of my job.
Brian
Message 4 of 12
braudpat
Hello
Welcome to the Autodesk/AutoCAD forums !
Maybe a stupid idea !
Could you select the objects in Capture Mode ?
Have you ONLY Pline Entities or have you some very old Trace Entities ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 5 of 12
maxim_k
Hi Brian,
That is what I'm talking about:
Here is Command prompt output during creation of polyline you see on screenshot:
Command:  PLINE
Specify start point:
Current line-width is 0.0000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]: w
Specify starting width <0.0000>: 10
Specify ending width <10.0000>:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: w
Specify starting width <10.0000>: 40
Specify ending width <40.0000>: 0
Command:
Have you tried to turn off object snap during polyline creation?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 12
BrianLUO
in reply to: braudpat
Turn off the capture mode from the icon shown in the attachment ?
Message 7 of 12
BrianLUO
turn off the object snap from the icon shown in the attachment ? It didn't work
Message 8 of 12
maxim_k
Does this issue with creating arrow with different polyline width happens in all files or just in one?
Could you post your file here (or just a portion of it with polyline already created as in your screenshot #3 from your first post)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 12
BrianLUO
It is not always. I tried this afternoon again, it happened occasionally.  The attachments include the command prompting and the process to the end. In addition, you will see some Chinese words as I use traditional Chinese as the language. If you don't know that, just focus on the command and foget about the Chinese things.
Thank you very much Maxim
Best Regards,
Brian
Graduate Engineer
FYFE
Message 10 of 12
maxim_k
Hi Brian,
I was able to reproduse your issue with polyline.
It looks like a bug (or feature?) of polylines with variable width.
If you will try to stretch with grips the end of polyline with constant width - you will see such effect.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 12
BrianLUO
Hi Maxim:
Thank you. It is now very clear for me with your help.  Today I am studying layout printing. How to put the pictures in the model into the layout with certain scale and place. In addition, I have no ideal about  the command "MView".
By the way, do you use some chat tools, like whatsapp, skype, msn or anything else? I sincerely want to be more closer to you.
Best Regards,
Brian LUO
Message 12 of 12
maxim_k
Hi Brian,
You can use IMAGEATTACH command to place raster images in Model and in Layout, than adjust scale with SCALE command.
About MVIEW command - you can use it to create Viewports in Layout (one ore more). After you create them, you can set scale foe each viewport and set Layer overrides (if you need them)
Here are a couple of links to video tutorials about creating Viewports in Paperspace in AutoCAD:
http://www.youtube.com/watch?v=nzuTNH-YCYA
http://www.youtube.com/watch?v=jQNqgA1KUbQ
http://www.youtube.com/watch?v=yVUzy8StJFk
About chat tools - yes I'm using Skype and iMessage you can send me PM on this case.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
