Solved by dmfrazier. Go to Solution.
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
A few ideas ...
1) Try to disable Hardware acceleration !?
2) Which values for the following system vars : DRAGP1, DRAGP2, DRAGMODE ???
Bye, Pat
Patrice BRAUD
Thanks for your quick reply !
How do you disable hardware acceleration?
And how do you find the values DRAGP1, DRAGP2, DRAGMODE?
Thanks again,
Good evening
3DCONFIG command.
Manual Tune button.
Try the Reset to Recommended Values button near the bottom of the dialog, or simply uncheck Enable hardware acceleration at the top.
You might have to experiment a little, changing one setting at a time, to see what works best.
If nothing works, then it may be that your graphics card is just inadequate for AutoCAD.
To see the values of the various DRAG... settings, just type them on the command line. The current setting is shown inside "carats", as in "<Auto>" or "<1>".
For more info on these and other settings, see Help, or you can also use the SYSVDLG Express Tool command.
