Hey guys,
i´m having a problem here..
when i try to save on my autocad 2013 normal, it works pretty well..
but when i try to save on compatibility mode it stucks.
what can it be?
thanks!
welcome @forums.autodesk.com!
Do you mean the setting "Maintain drawing size compatibility" in the options dialog, tab "Open and Save"?
If so: what objects do you have within your drawing that makes that setting necessary? (or do you have any vertical instead of plane AutoCAD)
- alfred -
by default, when you have only AutoCAD objects and not any objects from verticals or applications it should not be any problem.
And just as a guess, if you create a new drawing with just a few lines the saving back to an older dwg-format will work without problems, right? If that is right then it depends on specific drawings ... can you upload at least one of them?
And two additional tries:
a) command _OPTIONS, tab "Open and Save" ... play with the two checkboxes below of the "Save as" file-format
b) try to run command -EXPORTTOAUTOCAD with different formats to get the dawing back to an older dwg-format.
- alfred -
>> I´ve already tried to save a new drawing just with a few lines and the problem still continues
Can you upload that drawing?
Do you have a vertical product like Architecture or Mechanical or Civil3D ...? Or do you have an application sitting on top of AutoCAD that creates some proxies?
If you login to your Windows with another user-account (best would be: new account, admin permissions), is the problem then the same?
- alfred -
