AutoCAD 2013/2014/2015
Active Contributor
Message 1 of 12 (7,808 Views)
Printing from Autocad 2013 to PDF problems
7808 Views, 11 Replies
07-19-2012 09:00 AM
I just came across this problem in this version of Autocad 2013. I am trying to print my company logo into a PDF from autocad 2013 and it does but when i go open the PDF file it has lines all over it nothing is solid like the dwg file. Can someone tell me if this is a issued in Autocad 2013 and how to fix it because i done this in all other versions of Autocad and it printed find to PDF and everythig was solid with no lines all over the PDF. Thanks
Alfred.NESWADBA
Message 2 of 12 (7,807 Views)
Re: Printing from Autocad 2013 to PDF problems
07-19-2012 09:15 AM in reply to: ravencontrols
what driver did you use to create the PDF?
Not really, they are triangulated and also filled with lines, but maybe the lines have lineweights so you didn't see any white through it and so you think it's a solid.
- alfred -
Alfred NESWADBA
Active Contributor
Message 3 of 12 (7,806 Views)
07-19-2012 09:19 AM in reply to: Alfred.NESWADBA
i have always use cutepdf always here is what i am talking about. I printed things with cutepdf from inventor and its fine this is the first verison of autocad that this happens.
Alfred.NESWADBA
Message 4 of 12 (7,802 Views)
07-19-2012 09:22 AM in reply to: ravencontrols
please try the AutoCAD-internal "DWG to PDF.pc3" driver.
And for your PDF: use more lineweight for the objects on these filling-layers.
- alfred -
Alfred NESWADBA
Active Contributor
Message 5 of 12 (7,801 Views)
07-19-2012 09:26 AM in reply to: Alfred.NESWADBA
i just used the DWG to PDF driver and its still doing it. I never had to use more lineweights like you are talking about so i really dont understand what you mean from that. If you can explain to me what to do to better understand you with the lineweights. thanks
Alfred.NESWADBA
Message 6 of 12 (7,797 Views)
07-19-2012 09:49 AM in reply to: ravencontrols
can you upload the drawing, I'll try it on my machine.
- alfred -
Alfred NESWADBA
Active Contributor
Message 7 of 12 (7,794 Views)
07-19-2012 10:50 AM in reply to: Alfred.NESWADBA
Thanks for trying to figure this out for me. Here you go as per your request.
Alfred.NESWADBA
Message 8 of 12 (7,787 Views)
07-19-2012 12:17 PM in reply to: ravencontrols
I guess: you have looked to the PDF with Adobe Reader? If I'm right you have just to set some options in the Adobe Reader to get the display as clean as that:
Verify the settings that I have set. If the checkboxes are set similar to this screenshot then you would not see the fine lines again (same as when you plot from 2012, just tried it):
Sorry that I can't show the screenshot in english, I only have the German version installed, but I think the positons of the options are the same. Just start Adobe Reader, in the pull-down menu "Edit" look for something called like "Presets" or "Settings". Then you should come to this dialog, on the left side select Page-View and compare the checkbpxes then.
BTW: ever tried to plot this PDF, imho you should not see this lines on the printer.
- alfred -
Alfred NESWADBA
Active Contributor
Message 9 of 12 (7,786 Views)
07-19-2012 12:31 PM in reply to: Alfred.NESWADBA
Thanks that works and shows exactly like i want it to show. Thanks again for your help!!!
New Member
Message 10 of 12 (7,657 Views)
08-11-2012 11:56 AM in reply to: ravencontrols
I'm really having problems with print wth 2013 both with PDF and Plot. The print progam stop in the middle of plotting or PDF. The result is a 1/2 of a immage. I seem to happen in model space. AutoCAD 2011 plots the same file just fine.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
