I have updated to 2015 from 2014 and the printable area dashed line in paper space isn't showing up. I imported my settings from 2014 have checked
Display > Layout elements > Display printable area
my current work around is haveing display paper background checked and set it to a diffrent color. but i don't like doing this.
Is their something I am missing? works fine in 2014 but not 2015. useing all the same plotter files.
You can place settings on a network drive
and specify the path to it
Also check the printer configuration, they must be the same for both versions.
And the printing area can match with the sheet edge
Good luck,
Vitaly
It shows on my 2015 but the dashed lines are very short and light gray now where in 2014 they were much longer and white.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Matt, it looks like with the other forum post you were able to resolve the issue you were having?
Quentin Contreras
Technical Support Specialist
