I am running Map3d but believe this is fundamentally a vanila autocad issue. I have been searching for a solution for weeks and am surprised nobody else is having this issue.
When using my mouse wheel to zoom, the mouse pointer suddenly jumps to the top left corner of the autocad window. I don't notice at first, but suddenly the perspective of my zooming has become relative to that point. Sometimes I get 2 or 3 scrolls normally, other times it jumps right away. I thought it was my wireless mouse, but have had the exact same issue with a microsoft usb mouse. I have checked the middle mouse button settings and tried various options but no luck.
I am running on a new laptop with i7 processor, 20 Gig ram, nvidia gtx 670 mx video and Win 7-64 (especially installed for Map3d compatability with SQL server). Any help would be greatly appreciated before I go totally insane!
what version of Map3D do you have? And verify that you have installed the latest service pack for your Map3D >>>click<<<!
At least I have not seen that phenomen, also using Win7x64 but more often working with Civil3D than in Map3D.
I would start uninstalling the mousedriver, plugin it then into another USB port and install an new driver then.
HTH, - alfred -
I have worked around the issue by moving my license from my Win7 virtual machine to the native Win8.1 os. At least the mouse/zoom issue is resolved which is an easier poison to swallow than the SQL server compatability issues which I will deal with on another day.
I got the exact same problem on my VMware. In AutoCAD all works fine, but in Map the mouse jumps to the upper left corner.
For me, I found the solution in the following post:
http://www.cadtutor.net/forum/showthread.php?37701-VMWare-sluggish-selection-cursor-only
In VMware Fusion, go to Preferences.
In the "General" tab you have a drop down list next to "Gaming:"
Select "Never optimize mouse for games"
That did the trick for me.
