Hi!
I'm having few issues plotting my 3D model. I would like to plot visible edges so I can use it in Illustrator. But when I use "legacy hidden" in with plot commande (plot to PDF or EPS) half of lines are missing. When I use legay wireframe it works fine but then I have too much work deleting lines that I don't need. What can i do? 😕
Solved by drjohn. Go to Solution.
Solved by dgorsman. Go to Solution.
Try changing the HIDEPRECISION system variable. If your content is waaaaay out in space away from the WCS origin, moving it to the WCS origin may help as well.
