Currently my plot dialog box size default shows less options, and I'd like it to show more options by default.
How do I change the size default?
Using AutoCAD 2014.
Thank you,
Jim
Solved by doben. Go to Solution.
That does not change the default settings though for me. When I invoke the plot dialog box, I want it to show more options by default.
These are all the options available (see attached)
Click "Apply to Layout" to save your default plot settings for the drawing or click "Add" to make new ones.
Is this what you're looking for?
Interesting, well something stuck and now it opens fully expanded, even after closing and reopening AutoCAD.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
....... and now it opens fully expanded, even after closing and reopening AutoCAD.
@rkmcswain wrote:I still cannot think of any reason that PLOT and HATCH have a "hidden" set of settings
This a bit off topic from the OP, but there are a few other default settings that have baffled me: For example, why is the default for PLINGEN 0? And why is it a setting in the first place? Or why are some of the default command aliases longer than the command name itself? Maybe for those who love typing?
