Hi my friends,
i'm trying to plot to pdf a work by paperspace viewport. I've a sheet with 3 different viewport.. a rectangle viewport, and 2 polygonal viewport. Every viewport is on a definite layer called "RIQUADRO".
When plot to pdf, the two polygonal viewport disappear.. the rectangular viewport is ok. I tried to convert the rectangolar viewport to polygonal viewport .. and also the 3th viewport gone.
If make 3 rectangular viewport everything is ok.
If plot directly to my printer, everything is ok also with polygona viewport.
I can't find the problem. I've tried to create another one pdf style printer.. but nothing change..
Anyone???
Thanks mate
What driver have you then used to plot to PDF?
I would try it with the default "DWG to PDF.pc3", if that fails I would next look for a current servicepack for AutoCAD, maybe recreate a new "DWG to PDF.pc3" from scratch using the plotter-manager (sometimes when migrating from previous versions the usage of the old one has some issues) ... and if all that does not succeed then try e.g. PDFCreator.
Good luck, - alfred -
