AutoCAD 2013/2014/2015
Alfred.NESWADBA
Message 11 of 21 (171 Views)
Re: Pasting OLE...Unintentionally
01-08-2013 05:41 AM in reply to: sbrusco
do you have these 2 objects as DWG?
- alfred -
Alfred NESWADBA
sbrusco
Message 12 of 21 (167 Views)
01-08-2013 05:56 AM in reply to: Alfred.NESWADBA
Yes, as a single drawing.
Alfred.NESWADBA
Message 13 of 21 (164 Views)
01-08-2013 06:18 AM in reply to: sbrusco
including that errors too?
IMG1, upper issue: Large arcs get small arcs and lines
IMG1: lower issue: Same again, double-arc is converted to straight segment (twice, I marked only one position)
IMG2: upper issue: an arc is converted in a wrong direction (looking like a bumb)
IMG2: lower issue: a segment is missing at all
As long as there are only polylines (not curved or splined, just arcs and streight segments) I would guess such a tool should be done quite fast (as long as you are willing to get no elliptical arcs in the projection). Don't you have other geometry types included like symbols or text? Because that objects are the ones that makes up the work for development.
What do you do with this new geometry then? Is it just used to plot or do you use that within other drawings (or whatever goes on with that geoms)?
- alfred -
Alfred NESWADBA
sbrusco
Message 14 of 21 (159 Views)
01-08-2013 06:27 AM in reply to: Alfred.NESWADBA
Including the errors?? No, not including the errors. You didn't take long to find the reason i'm looking for another way. This is why i'm looking for an app to accomplish this for me, error free. And yes, we would like elliptical arcs/circles. And yes, we would like text to be converted also if possible.
I thought i had seen this mythical app before but i can't find it again. I wouldn't ask anyone to re-create it because i'm fairly possitive it is out there, somewhere.
Alfred.NESWADBA
Message 15 of 21 (151 Views)
01-08-2013 06:44 AM in reply to: sbrusco
no elliptical arcs (as in your sample, but free of bugs I think. Only TrueType-Fonts will not work that way I did .. just with plain AutoCAD, no tool necessary for that except ExpressTools!
Look to the attachment.
- alfred -
Alfred NESWADBA
sbrusco
Message 16 of 21 (146 Views)
01-08-2013 07:19 AM in reply to: Alfred.NESWADBA
That looks beautiful! Did you do this with an express tool? I must be missing that one.
So you have me hooked. How can i do this too?
Alfred.NESWADBA
Message 17 of 21 (136 Views)
01-08-2013 08:20 AM in reply to: sbrusco
The main steps are:
  • first rotate the geometry about the Y axis for 45°
  • use ViewCube to look to the model from 45° from below (how do I that say in english?)
  • then set the UCS to the current _VIEW
  • use command _FLATTEN (that projects the current geometry to the current view
  • copy the projected geometry into a new drawing (as the UCS is now rotated) to get it plane to XY
Look also to the attached video with higher resolution (any internet-browser or IrfanView or ... it's a flash).
HTH, - alfred -
Alfred NESWADBA
sbrusco
Message 18 of 21 (133 Views)
01-08-2013 08:59 AM in reply to: Alfred.NESWADBA
Alfred, this is F A N T A S T I C ! !   And you are fantastic.
Thanks for your time to put together the step-by-step AND the flash.
Alfred.NESWADBA
Message 19 of 21 (130 Views)
01-08-2013 09:15 AM in reply to: sbrusco
you are welcome. Glad that I could help :smileywink:
Be careful for any other object-types as I don't know all limitations that came with command _FLATTEN. At least I think you get a lot of objects clean projected going that way.
- alfred -
Alfred NESWADBA
Valued Contributor
Yorx57
Message 20 of 21 (116 Views)
01-08-2013 10:39 AM in reply to: Alfred.NESWADBA
Nice job Alfred! :smileyvery-happy:
I have an alternate method of also doing it, probably not any better, but I have experienced bad results with the flatten command at times.
Rotate the part (not the view) 30° (or what ever you want) in the Y.  I used the "rotate3d" command with the "y" option.  Rotate again by the same amount in the X.  Again, I used the "rotate3d" command with the "x" option.  Next, I used the "planesurf" command (surface tab -> Planar) with the "O" option.  Select the geometry and a surface will be created.  Finally, I used the "Flatshot" command to create a 2D view of the surface.
As for text, you can add that after - in either mine or Alfred's solution - and Truetype fonts will work.  First, find the angle of any of the "horizontal" lines ("properties", "list", etc.).  Create a new text style (with what ever font you want) and set the oblique angle to match the horizontal line's angle.  Create your text. Finally, rotate the text to the same angle used as the oblique angle.
Sorry, no fancy flash :smileyembarrassed:
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
