AutoCAD Forum
PROBLEM WITH COMMAND "FILLET"
17 REPLIES 17
Message 1 of 18
benjanowitz
1198 Views, 17 Replies
Hello everyone.
I'm having hard times facing these fillet problems
The fact is, I round some corners with the command Fillet, everything looks pretty good in the dwg file, but as soon as I export it to PDF, all the lines that I've "fillette-ed" look un-joined.
This dwg was given to me for my thesis, so I didn't draw it and I noticed that other lines (that I didn't make by myself) are having the same problem.
Please help me!!
17 REPLIES 17
Message 2 of 18
welcome @forums.autodesk.com!
I would not use _EXPORTPDF, I would run command _PLOT and use either DWG to PDF as printer (or my favorite alternative: PDFCreator).
Find attached my result based on your drawing.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 18
That's correct. I used the print path to export as a PDF 🙂
Message 4 of 18
And what driver did you use?
If you look to my PDF does that look ok for you (just to make sure it's not a viewer problem).
And as you are working on AutoCAD for Mac, it might be a help for you to search in the forum >>>AutoCAD for Mac<<< 😉
- alfred -
Alfred NESWADBA
Message 5 of 18
benjanowitz
in reply to: benjanowitz
I do exactly the same, but probably missing something in the general options, here you are a screenshot:
Message 6 of 18
benjanowitz
Thanks Alfred! Yes, I checked your pdf and seems ok!
Message 7 of 18
benjanowitz
I've opened the pdf file on Illustrator and it's pretty good. But still the arc line is not perfectly connected to the others or it seems to be...Am I right?
Message 8 of 18
From my PDF? Then I guess you have zoomed more than 400%
When I look to your screenshot (please notice I don't know the Mac version at all) I see you have set a Canon printer as plot-device. Is there no "PDF to DWG" device available in the Mac version of AutoCAD?
- alfred -
Alfred NESWADBA
Message 9 of 18
rkmcswain
benjanowitz wrote:
.... But still the arc line is not perfectly connected to the others or it seems to be...Am I right?
That is so tiny, you'll never see it.
If it is truly important, set your PDF dpi to 4800
R.K. McSwain     | CADpanacea | on twitter
Message 10 of 18
Hey, thanks Alfred!
Yes, I'm guessing I've zoomed too much and those lines were not joined toghether. Anyway...
I'm wondering if my problems are connected to a resolution thing.
Could you please post your settings in terms of
-Polyline curve segments;
-Arc & Circles smoothness;
Please?
And then, I'll do a REGEN to the draw and see what'll happen.
Regarding the plot question...
I'm using now a virtual printer instead the canon, but it seems not to work anyway.
I'm looking around to find a solution.
Thanks!
Message 11 of 18
rkmcswain
in reply to: Alfred.NESWADBA
Alfred.NESWADBA wrote:
I would not use _EXPORTPDF, I would run command _PLOT and use either DWG to PDF.....
Care to elaborate?
As far as I can tell, they both use the same driver to produce the output file. What are the differences? Thanks
Message 12 of 18
rkmcswain
benjanowitz wrote:
.....I'm guessing I've zoomed too much and those lines were not joined toghether.
Could you please post your settings in terms of .......Polyline curve segments...Arc & Circles smoothness.......And then, I'll do a REGEN to the draw and see what'll happen.
Those settings, regens, etc., only affect the on-screen display and not printed output.
Message 13 of 18
Alfred.NESWADBA
in reply to: rkmcswain
>> Care to elaborate?
Experience 😉
Most time someone had problems with EXPORTPDF the alternative _PLOT worked.
- alfred -
Alfred NESWADBA
Message 14 of 18
Looking through the rest of the file, I've noticed that's a big mess!
Look:
This is driving me I-N-S-A-N-E !
Message 15 of 18
pendean
MAC output to PDF relies on a system only option in that OS as you will find out soon with your post in that forum http://forums.autodesk.com/t5/AutoCAD-for-Mac-General/problem-export-pdf/td-p/5066702
Here in the Windows OS we have many more options and solutions to achieve better results. Sorry.
Message 16 of 18
rkmcswain
Experience 😉
I gathered that much. I'm asking for technical details as to why PLOT supposedly works when EXPORTPDF doesn't when they seem to be doing the same thing. Thanks
Message 17 of 18
Alfred.NESWADBA
Sorry to not have any proofed description why these two commands work sometimes different (at least similar to _PUBLISH and _PLOT).
It's really just learned from years of working with AutoCAD and support customers.
- alfred -
Alfred NESWADBA
Message 18 of 18
rkmcswain
......why these two commands work sometimes different (at least similar to _PUBLISH and _PLOT).
Interesting. I have not run across this, but it's entirely possible that nobody here is using EXPORTPDF too.
One thing I have noticed over the years is that publishing to PDF from SSM gives different results than publishing via the Publish command or just using PLOT
The latter seems to have problems with wipeouts, background masking, etc. (black boxes appear frequently but not all the time where these items should be), but when publishing from SSM, I have never seen this issue.
”Boost
