I am still having problems with display vs plotting to PDF
The display is looking ok, but the lines are missing on the PDF ie tees and flanges
My client is rejecting the outputs (correctly so) An I am at risk of losing my contract if I cant sort it
I have played with the view styles changing every variable
I can get it to plot correctly with some settings, but the text prints in yellow
Can someone help me
(The 3d objects were exported as 3d objects from revit)
The Acad file and the PDF are attached
Pete
Solved by alatier. Go to Solution.
