AutoCAD Forum
Ordinal Date
9 REPLIES 9
Message 1 of 10
copdahl
1256 Views, 9 Replies
Ordinal Date
Does anyone know if there is a way to format the date fields to display as an ordinal date? (ie. 21st of January, 2014)
9 REPLIES 9
Message 2 of 10
REID7800
in reply to: copdahl
you looking for  something like this?
%<\AcVar CreateDate \f "d of MMMM, yyyy">%
_____
Reid B.
_____
Acad 2015
Architecture 2010
Message 3 of 10
copdahl
in reply to: REID7800
Not quite. I need the ordinal version of the date where the day is listed
as 1st, 2nd, 3rd, 4th etc. Any ideas for that?
*Chantelle Opdahl*
Survey CAD Drafter
*MISSION*
GEOSPATIAL
[p] 403.668.4604 [f] 403.668.4622
[e] copdahl@mGeo.ca *www.mGeo.ca*
3320 8th Street S.E., Calgary, Alberta T2G 5S7
Message 4 of 10
REID7800
If you want to go the lisp way, I CAN help you with that. If not, this is all that I know for fields (as far as date stamps are concerned)... Let me know
_____
Reid B.
_____
Acad 2015
Architecture 2010
Message 5 of 10
AcadAdamLT
None of the standard field date variables that suites you?
use the "Field" command and see the different formats for yourself.
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
Message 6 of 10
hwalker
That's when I turned 44.
Unfortunately there is no OOTB answer
You would have to write a lisp routine which would
1. Get the date
2. Check the last digit
3. Add the following text depending on the digit
1 = st
2 = nd
3 = rd
4 to 0 = th
Howard Walker
Left Handed and Proud
Message 7 of 10
REID7800
(defun c:test ( / *error* date mtext pt )
  (vl-load-com)
  (defun *error* ( m )
    (or (wcmatch (strcase m) "*BREAK,*CANCEL*,*EXIT*")
         (princ (strcat "\n** Error: " m " **")))
    (princ)
  (defun date ( / fixday d )
    (defun fixday ( str / n )
      (strcat (itoa (atoi str))
        (cond
          ( (and (< 3 (setq n (atoi str)))(> 21 n)) "th" )
          ( (eq "1" (setq n (substr str (strlen str))))
            "st"
          ( (eq "2" n) "nd")
          ( (eq "3" n) "rd")
          ( "th")
    (strcat
      (fixday
        (substr (setq d (menucmd "M=$(edtime, $(getvar,date),MoDDYYYY)"))
          3 2
      ) " of "
      (nth (1- (atoi (substr d 1 2)) )
        '("January" "February" "March" "April" "May" "June" "July" "August" "September" "October" "November" "December")
      ) ", " (substr d 5)
  (defun mtext ( content height layer just insertionpoint flag / e )
    (setq e
      (entmakex
        (list
          (cons 0   "MTEXT")
          (cons 100 "AcDbEntity")
          (cons 67  0)
          (cons 8   layer)
          (cons 100 "AcDbMText")
          (cons 10  insertionpoint)
          (cons 40  height)
          (cons 71  just)
          (cons 72  5)
          (cons 1   content)
          (cons 7   (getvar 'textstyle))
          (cons 11  (list 1.0 0.0 0.0))
          (cons 90 3)
          (cons 63 256)
          (cons 45 1.1)
  	  (cons 441 0)
    (if (and e flag)
      (vlax-ename->vla-object e) e
  (if
    (setq pt (getpoint "\nSpecify insertion point of Date: "))
    (progn
      (mtext (date) (getvar 'textsize)(getvar 'clayer) actopleft pt nil)
  ) (princ)
 I couldn't resist! Smiley Happy
_____
Reid B.
_____
Acad 2015
Architecture 2010
Message 8 of 10
AcadAdamLT
Haha gotta love the entusiasm 🙂
AutoCad LT 2016
Message 9 of 10
REID7800
in reply to: AcadAdamLT
I noticed you're an LT user... here ya go!
_____
Reid B.
_____
Acad 2015
Architecture 2010
Message 10 of 10
Hi!
Is there any development in that would add the st, nd, th automatically? I still don't see a date type that offers that in the field creator tab, but I'm also not competent enough to do that lisp thing. 🙂
”Boost
