AutoCAD Forum
No Properties on the Home Show Tab
3 REPLIES 3
1050 Views, 3 Replies
There are no Porperties Tool Tab on the Home, it is hard to modify color and other properties. How to add it.
Tags (1)
3 REPLIES 3
kasperwuyts
The easy way to show the properties panel is pressing ctrl + 1.
You can find the button to enable the properties palette on the 'view' tab on the 'palettes'-panel
To get the properties button on the home tab you need to go to the manage tab and click the CUI-button, then copy the button from the 'view - palettes' panel to a panel on the home tab.
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
pendean
It's probably turned off: right-click over the Ribbon when in the Home tab and turn that panel back on. Check your other tabs for similar "off" panels.
in reply to: kasperwuyts
Thanks for your e-mail, from user manual, we can find the tool.
>From my AutoCAD 2015, Home tab as fellow:
Freundliche Gr??e / Best regards,
Weitian Li
PCT 1
Bayer Technology and Engineering (Shanghai) Company Limited
BTES-ENG-P1
Shanghai, Bayer Integrated Site Shanghai, SPC(2),A20
Tel: +86 21 61465598
Fax:
E-mail: weitian.li@bayer.com
Web: http://www.bayertechnology.com
Gesch?ftsf?hrer: Dr. Dirk Van Meirvenne
Aufsichtsratsvorsitzender: Dr. Wolfgang Plischke
Sitz der Gesellschaft: Leverkusen | Eintragung: Amtsgericht K?ln, HRB 49896
The information contained in this e-mail is for the exclusive use of the
intended recipient(s) and may be confidential, proprietary, and/or
legally privileged. Inadvertent disclosure of this message does not
constitute a waiver of any privilege. If you receive this message in
error, please do not directly or indirectly use, print, copy, forward,
or disclose any part of this message. Please also delete this e-mail
and all copies and notify the sender. Thank you.
For alternate languages please go to http://bayerdisclaimer.bayerweb.com
”Boost
