AutoCAD 2013/2014/2015
ADN Support Specialist
adam.nagy
Message 21 of 26 (246 Views)
Re: Need help with lisp routine.
08-08-2012 02:41 AM in reply to: jeff.whitney
Hi Jeff,
No, I don't have that tool. I simply looked into the acad.lsp file that Patchy uploaded.
Adam Nagy
Developer Technical Services
Autodesk Developer Network
Patchy
Message 22 of 26 (235 Views)
08-08-2012 03:55 AM in reply to: jeff.whitney
whitey14701
Message 23 of 26 (234 Views)
08-08-2012 04:00 AM in reply to: jeff.whitney
Jeff - when we run the len command it brings up 4 options which we have to input.
1) English or Metric
2) Pipe Diameter
3) Takeout in inches
4) Text height
Then we pick the endpoints of a line and it gives us the correct length that the pipe needs to be cut in the shop.
Distinguished Contributor
jeff.whitney
Message 24 of 26 (222 Views)
08-08-2012 07:43 AM in reply to: Patchy
Thanks!
adam.nagy
Message 25 of 26 (185 Views)
08-13-2012 07:52 AM in reply to: adam.nagy
I unzipped the content of lent.zip and then added the folder as the first Support File Search Path in Options, so that acad.lsp (that contains (c:len) definition) get loaded - tested in AutoCAD 2012
Then I ran the len command and it seemed to work fine and the layer switched back after using it.
I was thinking why it would not work for you and then I thought maybe you just use Esc to end the command, in which case the layer won't be switched back since the command execution gets interrupted and the layer switch back part won't be reached.
Try to just simply press Enter/Space bar when you want to quit the len command.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Adam Nagy
whitey14701
Message 26 of 26 (180 Views)
08-13-2012 08:26 AM in reply to: adam.nagy
Ok, so this is one of theose "DUH" moments. Yes id did work. A fellow co-worker asked the question and I guess I should have tried that before posting. Thanks Adam.
You are not logged in.
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
