I am using AutoCAD LT 2014 on Windows 7 64-bit. My CAD program has been crashing about once per week. Sometimes I am doing some work when it crashes, sometimes it crashes when I am away from the computer. Here is the event log from windows:
Faulting application name: acadlt.exe, version: 25.1.108.0, time stamp: 0x52216c79 Faulting module name: adlmint.dll, version: 7.0.51.100, time stamp: 0x5196c4a8 Exception code: 0xc0000005 Fault offset: 0x002e006a Faulting process id: 0x14f0 Faulting application start time: 0x01cf0bd8cea808a1 Faulting application path: C:\Program Files\Autodesk\AutoCAD LT 2014\acadlt.exe Faulting module path: C:\Program Files\Autodesk\AutoCAD LT 2014\adlmint.dll
Could someone please help?
Also,
I forgot to add... I have the program fully updated. I also have Autodesk 360 running (fully updated too) with Automatic Sync OFF but it does sync my settings. I recently turned off Hardware Acceleration to see if it would help my situation, but haven't reached a verdict on that yet. The last time my program shut down was Tuesday at 2:25PM and when it came back on it logged me off of Autodesk 360. First time I noticed that....
Autodesk 360 does Sync files into my 360 directory from other users though. That has been working fine.
I have also ran into the Windows Event Log Error:
faulting application name acadlt.exe
faulting module name ntdll.dll
Thank you,
@Anonymous wrote:
I am using AutoCAD LT 2014 on Windows 7 64-bit. My CAD program has been crashing about once per week. ,
I would say you are doing pretty good if it's only crashing once per week, assuming you are using it full time.
