Running Autocad Civil 3D 2014, multiple people in the office having this same problem.
For some reason trying to select multiple grips by holding down the shift key, doesn't or quits working.
Right now I have a polygonal viewport that I'm trying to resize around notes and other things and for some reason
it will not select multiple grips by holding down the shift key. But right next to the viewport I can draw a random pline
select it and hold down the shift key and the multiple grips selection will work. What gives???
A co-worker that is having the same problem can not even get the multiple grip selection to work at all on anything.
He has said that at times he was able to shut down Autocad and restart Autocad and his multiple grip selection would work
for awhile then at some point would not work again, today even when he shuts down and restarts autocad his multiple grip selection
will not work?
Anyone know a solution to this problem, especially mine where currently I can select multiple grips on some objects but not others???
While this article does not precisely describe your problem, it may be related.
http://beingcivil.typepad.com/my_weblog/2012/01/cannot-remove-selection-with-shiftpick.html
It might be this.
