These options are available for Mtext within a multileader, but not available for a block. I would like to set up small blocks with a letter or two of text within a circle to use in multileaders, which would have these same options. I'm very disappointed so far in all the options I've tried. Ideally I would be able to then x-ref the drawing, and the blocks would show up at the right orientation in multiple viewports at multiple viewtwists.
I'm a newbie at this, so please tell me I've missed something.
Mark Green
Working on Civil 3D in Canada
If I understtod your quest... Change the 'attachment' option in the CONTENT tab from Center Extents to INSERTION POINT and your leader will follow the edge of the circle while your text remains the right-way up.
No landing of course.
Thanks Dean, but they're already set to insertion point, sorry. Must be misunderstanding somewhere. What haven't I explained?
Mark Green
Post a sample file.
Have a look through the layouts; my hope was to find a style that would display the right way for reading or always horizontal in all layouts.
This drawing was created with Civil 3D 2013. Hope that doesn't mess you up.
Side note, I have found a solution for my situation using Civil 3D note labels, but that doesn't help anyone on this forum obvioulsly. Also, the note labels don't have the cool abitlity of multileaders to add a leader, subtract a leader. Multileaders would be nicer to work with in a few ways, but not if I can't get them to auto-rotate per viewport.
Thanks.
Mark Green
