AutoCAD Forum
Mtext - Seperation
5 REPLIES 5
455 Views, 5 Replies
Mtext - Seperation
All, I am having a weird issue with with mtexts in multiple drawings. When i click to edit the text it splits the text & in order to lose the split I have to delete the line of text & rewrite it. I have attached a video that shows the issue. Has anyone heard of this? Civil 3D 2013 https://www.dropbox.com/s/it9m7h9wyo729h4/Mtext%20Issue.mp4 Thanks All
5 REPLIES 5
murray-clack
It looks like the MText object ha a column assigned to it.  What happens if you remove the column from it (via the Properties Manager)?
in reply to: murray-clack
Based on your thoughts I tried the following: I turned dynamic columns off on the text itself. I changed mtextcolumn variable to 0 and created a mtext & pasted the information in I created a new mtext, & verified the colums were off and then manually typed the information in I tried to use a non annotative text style vs an annotative text. All with no succsess.
murray-clack
The only other thing I can think of is maybe try turning "auto numbering" off.  I remember having a piece of MText of general notes that went like this:
1.
2.
3.
of.
5.
6.
Where the word "of" (or whatever it was, I can't remember) was being treated like an autonumber list.
Murray, Thanks, that was it. For some reason it was treating it like a bullet or lettering.
murray-clack
Glad I could help!
”Boost
