I'm currently using AutoCad 2013 on a Lenovo Thinkpad X230 with windows 7 64 bit. I have 8 gb of ram and a core I7 processor which seem up to the task for the rather small files I create. My issue is that whenever I initiate the mtext command or attempt to edit an mtext object, my cpu usage will jump from about 0 to 4% up to 20 to 30% and will stay at that level until I close the drawing. This causes the fans to run constantly and makes working a little more jumpy. I've tried removing AutoCad completely and reinstlling. I've tried loading up AutoCAd 2014 (and subsequently removing it) and now I'm back to AutoCad 2013 and the problem persists.
I was wondering if anyone can help me debug this problem. I'm assuming it has something to do with the computer or some other software that is running in the background. It's odd that it would only affect this one command. The computer is only 1 month old and I've done the hardware checks that Lenovo offers (no problems indicated). Any help is greatly appreciated.
Solved by rzingre. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
What process uses the cpu in that case, the ACAD.EXE or anohter one?
What happens if you play with sysvars MTEXTED (e.g. setting that to "." or "OldEditor" >>>details<<<) and MTEXTTOOLBAR (>>>details<<<)?
- alfred -
